Changing Brake pads in a 98
Getting to follow the DIY write up for changing pads. Had a few questions before diving in:
Is it easy?
Can I use ceramic pads?
Signs on getting rotors resurfaced?
Do i need to bleed the fluid?
thanks in advance
Is it easy?
thanks in advance
RE: Changing Brake pads in a 98
ORIGINAL: jrcastro
Is it easy?
thanks in advance
Is it easy?
thanks in advance
B : you can if you want,, i rather stick with HONDA PADS
C : if steering wheel shakes while driving, deep grooves,
D : no need to bleed brakes
if you follow the directions on our DIY section you will be just fine
ssc280
04-27-2007 10:13 PM
thunder_x
09-13-2006 09:46 PM
