changing power steering fluid and brake fluid
If the brake fluid looks dark, I'd change it. Shop around for price. If you don't plan on keeping it for 200K, skip it. I did the turkey baster on my old Neon. You don't need to get 100% of the old fluid, you will improve he quality of the fluid. Repeat it a couple of time in a few days, you will get most of the old fluid out.
When I do the brake fluid, it suck out the reservoir, put fresh into the reservoir, then bleed down to the 4 wheels. (Keeping the reservoir full so it doesn't suck air) Maybe the dealer service-writer doesn't actually turn wrenches, so he simplifies the explanation & gets confused?
PS fluid is not called for replacing on any schedule that I've seen from Honda. So sucking the fluid out of the reservoir, you get about 1/3 of it out. Run awhile & repeat, it gets cleaner each time you do that. After all, that's how most of us do ATF changes, and it's a lot better than leaving the fluid in FOREVER.
I personally have never bled brake fluid out of my lines, unless doing caliper work etc..
What I have done is use a turkey baster and periodically suck out and refill the reservoirs on both the power steering and brake fluid systems.
On the power steering system, I use Lucas power steering fluid with conditioners, which is safe for Honda's (so they claim) and I have never had any PS issues.
Good luck!
Good luck!
62maxx
10-18-2015 09:20 AM
