check engine light coming on
RE: check engine light coming on
ORIGINAL: doanutboi
your gonna need an OBD2 reader to find out the code. the plug is located behind the ashtray under the radio. after that you can just google the code and it will show you the problem.
that is why i always ask people to input info about the car in the signature ...
Aboutblank, please input year and model in your sig ...Thank-you
ORIGINAL: 00AccordLX5spd
and the service connector is not behind the ashtray, it's under the dash.
ORIGINAL: Chiovnidca
1990 accords dont have a connector to jump. It should have an led on the ecu. (if it's the stock ecu)
so i took it to a shop and got the correct code coming out of it and it says that its the VTEC oil pressure switch.
i think its by the solenoid if im correct but i dont know how to tell if i need a new one or what
1990 Accord LX
92 JDM h22a
exeddy stage 1 clutch
1990 Accord LX
92 JDM h22a
What was the EXACT CODE NUMBER? Example: P0123
I don't ever trust what the "shop" says.
Even if I took my car to the Honda dealer, I would ask them for the exact code number.
#17
If you go to http://www.dhost.info/accordinfo/ and click on cylinder head valve train, a pdf opens that you can click on oil pressure switch. It goes through a test procedure. This is for a 94, but I will assume that it should be similar to the 90 accord.
I just read the previous post, I think that your car is OBDI, so the two possible codes are 21 or 22. On the top of that dhost page, there is a link for CEL code retrieval. Its very easy to do, so give that a shot. You might have to look at the ECU if the check engine light doesn't flash.
Winston Hart
09-07-2013 12:32 PM
bobbybriggs01
08-21-2013 06:14 PM
78gaw
01-20-2010 09:45 AM
PAY1920
07-01-2007 09:58 PM
