Check Engine Light/Readiness Codes
Old 12-21-2011 | 04:35 PM
rah140's Avatar
Default Check Engine Light/Readiness Codes
I have a 2012 Honda Accord and apparently the battery ran low when it was at the dealership and now when I turn the key to the on position without the engine running, the check engine light goes out after 20 seconds and then blinks 5 times. The owner's manual says that the readiness codes aren't set. How can I fix this problem so the diagnostics operate normally?
Thank you.
Old 12-21-2011 | 06:06 PM
This should resolve itself when all system checks are complete.
If it persists for more than a day or so, I would return to Honda for diagnosis.
Old 12-21-2011 | 06:09 PM
rah140's Avatar
It's been 4 days now. I called the dealer and they said the readiness codes cannot be reset manually and will reset automatically.
Old 12-21-2011 | 08:47 PM
Depending on how much you drive and that it could take a bit. They (the dealer) should be able to tell you the conditions the car has to be driven in to set this.....
tiotico
07-31-2012 09:04 PM
dacecil
06-21-2012 07:27 PM
daemon44
03-07-2009 07:58 PM
DadofFour
10-10-2007 07:34 AM
aytgy
09-08-2007 04:38 PM
