Clean Pistons with Head Removed?
Old 04-23-2013, 02:19 PM
Dr. Drivability's Avatar
Originally Posted by 5.0stang
The increase in compression you are talking about is only from a static position, but what about total swept volume? That would decrease your compression.
are you talking about the volume of the air/fuel mixture being drawn into the cylinder?
Old 04-23-2013, 02:35 PM
5.0stang's Avatar
Swept Volume (volume at TDC to BDC) - same effect as decreasing the stroke of an engine, will decrease the compression, all else being the same.
Old 04-23-2013, 02:42 PM
it would be variable depending on how much carbon was on the piston and deposited in the combustion chamber itself, but we've done top engine cleanings for varying reasons, smog failure, detonation etc...and have seen compression numbers drop.
Old 04-23-2013, 03:05 PM
5.0stang's Avatar
You are right; there would be a ton of variables involved.
Old 04-23-2013, 03:08 PM
gotta take these on a case-by-case basis sometimes
joshcolorado
07-03-2013 09:58 PM
the cyclops
07-24-2011 03:05 PM
dan_o_89_rs
09-10-2007 10:52 AM
SandMan
08-20-2007 03:34 PM
befuddledblunt
12-12-2006 08:25 PM
Quick Reply: Clean Pistons with Head Removed?
