Clearing SRS light
Clearing SRS light
96 accord 2door 5speed vtec f22b1
So i found the two wire connector thats right by the fuse box and the wire color is gray gray
So i jumped the wires using a paperclip turn on the key switch
And the light dint go off after 6 seconds ( like it says in the DYI thread ) light remains on
Any help would help alot
Are you sure that you have the right connector?
When sitting in the driver's seat: the yellow two pin connector is pretty close to your left knee. It is just behind that plastic panel (that piece with the change holder) towards the bottom. It is plugged into a dummy connector.
Doode i read the DYI several times
Im using a paperclip to jump the wires yes i found the yellow two pin connector that rite by the fuse box the color wire is gray gray and it is stuck toa dummy connector
Used a paperclip got it real good inside turned on ignition switch and nothing light just stays on I tried a diffrent method i read in another thread i usedd speaker wire tried that method no luck
My car was salvaged and on the passenger side the airbag looks like it deployed already has a big crack down the middle as if it popped before
