Climate Control Issue, no light, no control 98 accord
Old 09-13-2007 | 07:58 PM
greenbean
Default Climate Control Issue, no light, no control 98 accord
The climate control panel in my 98 accord LX has a random issue.
If the light is lit above a button, say for the floor vents, I can switch to another option, like the defroster, but more often than not, there's no light lit on the panel and I can't change where the air comes out. I can increase fan speed, but that's it.
The rear defroster is also out of commision when the panel isn't working. With winter around the corner I'm worried about keeping my rear window clear and having a safe drive to work in the snow.
I've read about solder joints possibly going bad. The summer heat hasn't seemed to influence when the panel goes dead. Pulling the panel enough to wiggle wires hasn't shown a short either. Please help!!
Old 09-14-2007 | 12:05 PM
Default RE: Climate Control Issue, no light, no control 98 accord
I have heard of possible problems w/ the connector to the climate control (in general, not Hondas specifically). Fix was to pull connector and clean contacts w/ a rubber eraser. Apparently some of them are very low voltage/amperage and a high resistance connection can cause problems. All this is 2nd hand, hearsay as lawyers say. If that doesn't work, I would look to a used climate control. Some used parts places will let you do a swap w/ a no-fix, no-pay arrangement. Check car-part.com for used parts near you. You will probably have to call to find an ATC instead of the manual. Not sure how difficult it would be to substitute the manual for ATC.
Add your car description to your signature line for quicker responses and less confusion.
Old 09-21-2007 | 03:14 PM
greenbean
Tried cleaning the contacts, but it still had the same issues. Ended up buying a used Climate Control Panel online. Cheap fix and things seem to be working well.
I'm guessing the problem is somewhere in the circuit board connected to the panel, but I didn't tear into it to see if something looked fried.
I appreciated your input TexasHonda. Thanks!
candoan
08-16-2013 06:22 PM
kirk78h
08-06-2011 10:06 PM
rolling
02-10-2011 09:09 PM
pdude
08-21-2008 11:33 AM
jtysinger
10-31-2007 03:47 AM
Quick Reply: Climate Control Issue, no light, no control 98 accord
