Climate Control Temperature Blinking
Old 01-09-2013 | 08:09 AM
Michael Meeker's Avatar
Default Climate Control Temperature Blinking
Hi All,
I have a 2005 Accord Hybrid and when I started it up yesterday, the numbers that show what the cabin temperature is set to were blinking. It is similar to what you see when an alarm clock loses power and the numbers on the clock are blinking.
The heating/cooling system still appears to work - I am getting hot and cold air when I increase the cabin temperature setting and decrease it.
It is just really annoying to have the numbers for the cabin temp blinking. Is there some sort of hidden setup mode for this that I accidentally activated?
Thank you for your help!
Mike
Old 01-09-2013 | 08:30 AM
Dr. Drivability's Avatar
there is a problem in the system. the idle stop feature for the hybrid system will be disabled. you need to pull the self diagnostic codes from the a/c unit. the codes are a - z. redbull will probably have a link or document telling you how to do this. when you get the code(s) report back.
twcinnh
01-30-2008 06:03 PM
Tony1M
01-05-2008 12:22 PM
greenbean
09-21-2007 03:14 PM
Karthigan
11-27-2006 02:55 PM
Quick Reply: Climate Control Temperature Blinking
