Clock Bulb Replaced, Guages Don't Work Now...?
Old 05-11-2008 | 10:37 PM
Calidude87's Avatar
Default Clock Bulb Replaced, Guages Don't Work Now...?
I jsut replaced the mini bulb in the digital clock in my 2000 LX coupe, and as soon as I reconnected the clock/hazard light assembly and turned on the car, the guages stopped working...completely. No tach, no speedo, no oil pressure, no mileage/trip display, etc...I have searched and found how to reset ECU but that didn't work, so if anyone has any idea please let me know! Thanks!
Old 05-12-2008 | 06:54 PM
Calidude87's Avatar
Default RE: Clock Bulb Replaced, Guages Don't Work Now...?
Bump...help!!! Also, power windows do not work now either!
Old 05-12-2008 | 07:58 PM
Suggest checking your fuses, both underhood and underdash. If they are all OK, check your work on the dash clock (wiring damage or wires pinched under a screw or bolt.
Old 05-12-2008 | 08:14 PM
Calidude87's Avatar
Thanks I will do that, I hope it is just a blown fuse, I didn't really mess with the wiring just unplugged and replugged...oh and the clock light still doesn't work either...thanks again
Old 05-12-2008 | 10:36 PM
When things that should be unrelated, like windows, gauges & clock; when they screw up together, it's a good idea to check for loose/disconnected ground wires.
Old 05-12-2008 | 10:45 PM
Calidude87's Avatar
Which ones are the ground wires?
Old 05-13-2008 | 12:09 AM
finch13's Avatar
The black ones screwed onto the metal frames and the chassis. You'll find them everywhere, but check in the area you worked and near the fuse panel.
Old 05-13-2008 | 01:14 AM
Sounds like a blown fuse to me.
I'm looking at the 95 shop manual and the number one fuse in the under dash fuse box controls the gauge assembly, clock light, etc and is a 10 amp fuse. The 2000 accord could definitely have a different setup since it is a new generation accord.
Old 05-15-2008 | 03:01 PM
Calidude87's Avatar
Well I checked the fuses and ground wires and everything, and I still can't seem to find the root of the problem...however I did notice in the fuse box on the interior driver side that there were 2 connectors just hanging freely; I have an aftermarket head unit though so this may be why, I'm not sure. Thanks for all your help, I think I will just take it to my friend who's a mechanic at a Honda dealership.
Old 05-22-2008 | 03:27 PM
Calidude87's Avatar
Ok, finally got around to checking all the fuses, as I noticed that my backup lights were no longer functioning as well as my needles and mileage reading/trip, and power windows. Sure enough, I rechecked fuse #9 on the driver side fuse box, and it was blown. As soon as I replaced the fuse, everything worked perfectly, even the clock light! So a word of advice: if you want to replace the clock bulb, make sure you cut the wires that extend off of it before putting it into the clock, as I believe when I did not do this it put too much power to the fuse and blew it. Another word of advice, if you are having this same problem, it is probably FUSE #9 IN THE DRIVER SIDE INTERIOR FUSE BOX. Thanks for your help
Pajamarama
06-08-2012 08:57 AM
Jaz
03-19-2012 09:55 PM
widowmaker
06-02-2011 04:21 PM
hondacow
04-20-2008 02:02 PM
old88dog
06-13-2007 10:58 PM
Quick Reply: Clock Bulb Replaced, Guages Don't Work Now...?
