Clutch AGAIN !!!
Old 10-27-2011 | 08:58 AM
D-ODD-1's Avatar
Default Clutch AGAIN !!!
Ok so i had replaced my clutch just about 2months or so.
But here is my problem im having when the car is cold the clutch pedel feels fine smooth n good but as the car gets warmer the clutch feels hard n harder. What can cause this issue cause this car is becoming a NIGHTMARE.
Old 10-27-2011 | 07:32 PM
I'd need a bit more info. Did you change the fluid when you did the clutch?
Also I'm assuming the pedal is harder to push, not that it gets harder for the car to go into gear.
Old 10-30-2011 | 11:48 AM
D-ODD-1's Avatar
Yes i changed the fluid plus master n slave cylinder. Yes it gets alot harder to press in the pedal plus then it will be up so high for it to grab.
Old 10-30-2011 | 12:41 PM
Inspect the slave mounting. Also where the "pin/piston" contacts the clutch fork.
Old 11-01-2011 | 10:01 AM
D-ODD-1's Avatar
There good looks like some how im losing small amounts of fluid cause i will fill it n 2 weeks it will down a little.
bigb609
12-27-2011 08:18 PM
fireballer44
06-07-2007 10:35 AM
07-24-2006 04:55 AM
tamb
07-21-2006 02:05 AM
06-02-2006 03:24 AM
