Clutch Master Cylinder
Old 08-15-2006 | 03:30 PM
fireballer44's Avatar
Default Clutch Master Cylinder
This should probably be an easy question for someone.....not on an Accord, mine is having the bumper replaced--but an Acura Legend is similar enough
Should I see any fluid on the clutch master cylinder on the inside of the car. The clutch isn't working well--and I see fluid on that side. Do I need to replace it or rebuild it??
I am working on it as we speak, have no car to drive at all , anyone have a quick clue please respond.
Old 08-15-2006 | 08:42 PM
Default RE: Clutch Master Cylinder
Well, no one that knew what was going on posted.......
I replaced the clutch master cylinder and bleeded the system. All is well!
Old 08-15-2006 | 09:34 PM
mbo1985's Avatar
glad to hear that... I just got home from work, otherwise I would have responded, and I'm sure others were stuck in similar situations. Sorry no one replied quick enough, but glad you took things into your own hands and everything works.
Old 08-16-2006 | 12:42 PM
Yeah, fluid leaking inside the car isn't good. You did the right thing.
nascar2806
07-03-2011 07:49 PM
98accordlx
02-27-2011 04:56 PM
crenshawjason
05-25-2010 07:34 AM
magowie
05-13-2010 07:03 AM
ZMan3000
05-22-2008 03:57 PM
