code 1259 need help
Old 07-07-2006 | 12:00 AM
kilawind
Default code 1259 need help
help
problem code 1259 vtec related problem, I tested oil presure switch and the solenoid like the book said. Still have the same code after i replace the whole thing. both fans are on too,soon as you start the engine.what could it be?
Old 07-07-2006 | 12:06 AM
Default RE: code 1259 need help
Hi Member...
I believe that code 1259 is a false code given out by the PCM..
I or one of the other members will look it up for you shortly..until don't fret, it will be known by one of them..
Thanks for joining up..
WheelbrokerAng [sm=americanasmiley.gif]
Old 07-07-2006 | 12:24 AM
Chiovnidca's Avatar
The pcm doesnt give false codes. It only codes when it sees a problem. When i get one with a p1259, the first thing I do is check the engine oil. a low level will cause it. If the oil is good I check to see if the engine is a sludge monster.
Old 07-07-2006 | 12:42 AM
mbo1985's Avatar
if both fans are on when you start the car, it could be because you have the A/C on. Try to figure out what's causing the problem before replacing things. There's nothing worse than replacing a bunch of stuff to find out it was something simple and cheap (been there, done that!).
Like Chiovnidca mentioned, hows the oil level look? Have you replaced the filter recently?
Old 07-07-2006 | 02:38 AM
kilawind
thanks for the reply guy`s appreciate it
Old 07-07-2006 | 02:44 AM
kilawind
Yes, I double check it before i start the car and both fans continuously on all the time while the car is running. When i unplugged the V-tec oil pressure switch both fans will stop hmmmmmmmm.
Old 07-07-2006 | 02:48 AM
kilawind
I have a pocket logger that is compatible with OBD 2 Honda's, that`s how i erase the check engine code. Engine code erase step on the gas rev over 4,000 rpm check engine come backs on some times 1259 sometimes p000.
Old 07-07-2006 | 09:31 AM
Chiovnidca's Avatar
ORIGINAL: kilawind
You sure the vtec pressure and thermoswitch connectors didn't get switched around?
corporategohan
02-20-2009 10:22 AM
Mysticalbeauty3
10-06-2008 04:17 PM
Mysticalbeauty3
10-06-2008 04:17 PM
rtmd01
07-09-2007 11:04 AM
Uncle T
08-01-2005 10:11 PM
Quick Reply: code 1259 need help
