Code 14, Bad ECM?
Code 14, Bad ECM?
Recently replaced my ECM to repair a no start issue and my tranny started shifting rough. Had no D4 light so took my cluster apart and swapped my 1 bulb for D4 and it light up blinking. Shorted connector and it reads a 14.
While I will do a check on the brn/wht wire between ECM and D16 terminal I am concerned that since I just replaced the ECM that is what it is. Has anyone dealt with a 14 before? Thanks in advance.
Replacement ECU fixed my problem. Noticed that the ECU I bought prior to this one had m/t stamped on it and my new/used one had a/t on it. Probably why the D4 light was giving a 14 code. Guy assured me the m/t one would work with my a/t.
Only way to be sure of getting correct ECU/TCU performance is to exactly match the part number on the original.
We all make mistakes. I accidentally order a MT ECU when I was looking for AT ECU recently. I managed to resell on ebay and recovered my cost.
