Code P0137 & P0139 showing up on 06 Accord
Old 05-11-2011 | 08:11 PM
ajvasquez's Avatar
Default Code P0137 & P0139 showing up on 06 Accord
Please help...I have a 2006 Accord VP, 4 cyl, 2.4 liter engine. My check engine light (CEL) came on about a month ago. I went to Auto Zone and they told me that it had two codes (P0137 & P0139).
P0137 reads: Secondary H02S12 (heated oxygen sensor - bank 1 sensor 2) circut low voltage.
P0139 reads: Secondary H02S12 (heated oxygen sensor - bank 1 sensor 2) circuit slow response.
Auto Zone told me to replace the downstrem sensor (in the cat). I bought one on e-bay and replaced it. Reset the ECM and my CEL came back on. I did some research and found that I should ohm the sensor. The original sensor is ohming a 6 ohms. The new sensor is ohming at 10 ohms. Both ohm good according to my research.
I don't know what to do next...What wires do I check or do I have another problem like a lean air/fuel ratio? How would I check?
Thanks for your help,
ajvasquez
"America is best described by one word, freedom."
--Dwight D. Eisenhower--
Old 05-12-2011 | 11:41 AM
You would measure the resistance if you had a heater problem (P0141). Measuring between the 2 black wires is the heating element, not the sensor itself.
You can't measure the resistance of the sensor itself at room temperature.
Old 05-12-2011 | 11:04 PM
ajvasquez's Avatar
What do you suggest I do now? I'm completely lost
ajvasquez
Old 05-13-2011 | 08:25 AM
Either you purchased a faulty sensor, or there is a fault in the wiring or connector to the sensor.
Suggest disconnecting the sensor from harness and inspect connection/wiring carefully for damage. Clean connectors w/ contact cleaner and install some electrical grease in the connectors. Reinstall and reset ECU and see if codes return.
If codes return, this suggests a fault in the wiring somewhere between sensor connector and ECU. You will need to disconnect the connector w/ the sensor wires from the ECU and from O2 sensor, and check for faults in those two wires (Check for short to ground first, then ground one end and check that ground is available on other end). Tedious check but necessary.
If all checks good, the ECU board may have a fault. This is unlikely but possible.
Old 05-13-2011 | 11:52 PM
You bought the sensor from ebay... was it used? A bad sensor would be my first suspicion.
Drpepper
12-07-2017 10:51 PM
Roader
01-19-2013 10:23 AM
steved89
09-29-2012 08:08 PM
bdho98
08-12-2012 11:04 AM
amanb
12-14-2008 08:14 AM
