Code P1491.....
Old 05-19-2006 | 01:35 AM
2001 Accord VTEC
Default Code P1491.....
Hi!
Check engine light is came on and I checked it with OBD II Scanner and he found one problem: Manufacturer Controlled; Auxiliary Emission Controls.
Please help me, what I need to do?
Thanx!
Old 05-19-2006 | 04:27 AM
deserthonda's Avatar
Default RE: Code P1491.....
ORIGINAL: 2001 Accord VTEC
Hi!
Thanx!
code p1491 ,, is an issue with the EGR system...... to be exact, EGR insufficient lift
call the local dealer, and ask if it is stil under warranty , or if there is an warranty considaration..
If NO , to both questions and you want to troubleshoot it , let me know ,,i can walk you throught it .. but you got to have a good multimeter ,,
Old 05-19-2006 | 07:29 PM
2001 Accord VTEC
I cleaned EGR and I think now is everything OK with it but now OBD shows P0131 - O2 Sensor Low Volts, maybe I spayed sensor connector with electrical spray!?
vuuli312
04-14-2014 08:19 AM
oneloudskunk
05-01-2011 02:52 PM
Racemaster
01-15-2011 06:41 PM
dhalla196@rogers.com
03-07-2007 09:21 PM
BertMan
01-30-2007 02:15 AM
Quick Reply: Code P1491.....
