Collapsing power steering hose
Old 11-13-2008 | 03:16 PM
gtrplr2
Default Collapsing power steering hose
I have a 1994 Accord Ex 4 cyl coupe. I start it up and let it run for about a minute and it begins doing the RPM surging thing about every 5 seconds. One of the hoses on the power steering collapses completely flat. Are the two problems related? Can a faulty power steering pump cause either of the problems? Any insights leading to resolution will be DEEPLY appreciated.
Old 11-13-2008 | 03:57 PM
finch13's Avatar
Default RE: Collapsing power steering hose
Use the link in my signature below to search "surging idle", this is most likely a dirty Idle Air Control Valve.
The power steering hose you mention is likely the hose on the suction side of the pump (this hose goes from the pump to the bottom of the power steering fluid reservoir), the other side is the pressure side. Probably isn't an issue.
lonberge
10-01-2010 08:59 AM
fatswany
10-11-2007 06:54 PM
Wilsco
11-20-2006 06:53 PM
Bobby W
06-30-2006 01:15 PM
