Coolant Drain Plug Stuck Solid!
Old 12-09-2007 | 09:08 PM
Accord_Ras's Avatar
Default Coolant Drain Plug Stuck Solid!
I'm starting to regret that I ever decided to buy a honda. I've owned all the major Japanese brands...along with a few European (Benz, Jaguar etc.) and nothing has been a greater PITA! than this honda!. Today I decided to change the coolant (previous owner had it running on pure water!!!) I used a heavy duty torque wrench...thinking it would be a snap getting off that 19mm bolt. Well, the bolt refuses to budge but the head gave way...it's now completely rounded! The long and short of it is that I couldn't drain the block....just the radiator. Thing is, the manual says total coolant capacity is 2.7 US qrt. This includes the resevoir. Well, without being able to drain the block, thesystem took 1 US gallon!almost twice the stated capacity.What gives? and how do I deal with the bolt?...get it drilled out or just leave it be?
Old 12-09-2007 | 11:58 PM
nafango2's Avatar
Default RE: Coolant Drain Plug Stuck Solid!
use some extractors on the bolt. you can get them at sears for $5 or so for two.
also you cant listen to shop manuals, you have a rare engine, i wasnt even aware that the F20B was an option in the 96's... maybe an engine swap?
Old 12-10-2007 | 12:20 AM
We never got the F20 in USA in '96. But we don't know where he is...
Old 12-10-2007 | 08:00 AM
Accord_Ras's Avatar
ORIGINAL: JimBlake
You are correct...i'm outside the US and the car is a JDM model
Old 12-10-2007 | 08:11 AM
Accord_Ras's Avatar
ORIGINAL: nafango2
It seems the bolt has fused to the surronding metal...believe me, tremendous torque was applied. If the bolt head had not given way, perhaps the engine block itself would've been damaged. I think i'm just going to leave it be and do another partial drain and refill in order to get as close as possible to a 50/50 coolant mix
Old 12-10-2007 | 11:21 AM
Each time I've removed that drain plug it takes a lot of torque, then lets go with a loud SNAP. It's worse the first time on each engine. So NEXT time it probably won't be so bad.
sgull
11-20-2014 10:19 PM
hondafreak2
12-15-2006 07:43 PM
Ronin_301
07-05-2006 01:54 AM
