Cooler thermostat?
Old 10-31-2012 | 10:11 AM
RobinsonRicer's Avatar
Default Cooler thermostat?
So I did some research on this... my car runs kinda hot and I had the thermostat replaced some time ago by an 'at home' mechanic, trying to figure out why my heat wasnt working. That wasnt it. But I have another thermostat in my car. I have no idea what temp it is, probably 190. They dont sell 200 degree ones do they? My car stays around 200-5 degrees when fully warmed up. I found a thermostat for 170 degrees and am thinking about putting it in.
Anything I should know? Ive read that the ECU has to be retuned to kick on the fans early but thats not possible with the stock ECU. Is it worth doing something about that? Maybe a resistor or something on the fans?
Or can I get away with just installing the cooler thermostat and get my engine temp to drop a bit?
Old 10-31-2012 | 10:22 AM
Dr. Drivability's Avatar
197 degrees is the temp when the stat is fully open. where does the needle on the gauge sit when at operating temp?
Old 10-31-2012 | 10:52 AM
a little bit below the middle point. about a 1/4 of the distance between cold and medium.
My gauge- which is now broken- always read 205+/-
Old 10-31-2012 | 11:11 AM
nothing wrong with that temp, mine runs at about 202-203 when the fans come on, the emissions systems require the engines to run at these temps. wouldn't worry about it...a cooler stat would cause you more trouble than you would fix.
Old 10-31-2012 | 11:36 AM
Ok. thanks. I guess thats one less project. But I can focus on other things.
cbrf4i1
01-06-2008 05:08 PM
DoctorSub
08-03-2006 09:40 PM
marbro
05-03-2006 09:45 PM
fryhead
02-16-2006 04:04 AM
sdfollmer
11-13-2005 09:11 PM
Quick Reply: Cooler thermostat?
