cooling fan not on at idle for 93 accord
Old 06-18-2011 | 04:05 PM
gingle37's Avatar
Default cooling fan not on at idle for 93 accord
I have a 5 speed 93 accord, 2.2. I am overheating at idle due to cooling fan not coming on. I know the fan itself works as it comes on after running the car and parking it. I switched the pw window relay with the fan relay, no better. Fuses are good. Anyone seen this before?
Old 06-18-2011 | 04:21 PM
Do both fans turn on when the a/c is turned on?
Old 06-18-2011 | 06:12 PM
gingle37's Avatar
yes, both come on with the ac.
Old 06-18-2011 | 06:19 PM
The most likely cause is the temperature switch A that is on the thermostat housing needs replaced. In the DIY common threads sticky has a link for an explanation.
The OEM part number is 37760-P00-003.
If you want to avoid overheating, you can short that connector to the sensor using a piece of wire with the car turned off. When you start the car, the fans should run all of the time. This is better than overheating and is a temporary fix until you replace the part.
If shorting that connector doesn't make the fans work when the engine is running, then you will have to troubleshoot further.
Old 06-18-2011 | 06:25 PM
gingle37's Avatar
Sounds good, I'll give it a try. In traffic jams been running defrost heat to bring temp down. Just too dang hot for that in the summer. Thanks for the info.
Old 06-18-2011 | 06:41 PM
You can run the a/c as well. You already verified that the fans work with the a/c on.
Old 06-18-2011 | 09:14 PM
gingle37's Avatar
Well, I have tried that but for what ever reason the defrost heat seems to do a better job of cooling it down? But for sure both fans come on with the a/c.
Old 06-19-2011 | 08:32 AM
Humm, even with the ac on (both fans running) the car will still start to overheat?
I that is true there may be another issue.
Old 06-19-2011 | 08:05 PM
Another issue like a radiator with obstructed water-flow passages. Or a lot of crud on the radiator, blocking air flow.
Old 06-24-2011 | 05:36 PM
gingle37's Avatar
Thanks for all the input. Had to replace the radiator yesterday due to a crack in the neck. Was gonna replace temp switch A, but found it un-plugged? Plugged in in hopes the cooling fan would come on, but to my surprise it didn't! Guess I need to go ahead and get one. By the way, how exactly can I short out that connector for temp switch A at the thermostat before buying a new one?
Quick Reply: cooling fan not on at idle for 93 accord
