Cooling Fans Issue
Old 03-25-2019, 12:21 PM
TexomaAccord's Avatar
Drove it, flashing cel...
  #72
Old 03-25-2019, 01:26 PM
Pcv valve was clogged. Cleaned it. Let's see
  #73
Old 03-25-2019, 04:09 PM
Drove 15 miles at 55mph to get inspected
Temp never got above 170
No cel lights ever
Went to back out of inspection, wouldn't start
Had to bang on starter
Drove home 15 miles at 55.
No cel, temp never went above 170
  #74
Old 03-25-2019, 04:21 PM
Seanjordan20's Avatar
So we know that there is no blockage in the system. Did you have to stop at some point. Did you notice the engine temp raise when you had to stop? If not then the only thing it can be is the thermostat.
  #75
Old 03-25-2019, 04:36 PM
During the drive it stayed around 159. Stopping at lights stop sign it got to 170
  #76
Old 03-26-2019, 04:22 AM
When you got home was the cooling fan cutting on. It seems to me everything else is working as it should.
  #77
Old 03-26-2019, 08:24 AM
Negative. Temp never seemed to get hot enough for the switch to activate the cooling fans
  #78
Old 03-26-2019, 08:30 AM
Of course there was no thermo in. I would put it back in and focus on the fan
  #79
Old 03-26-2019, 08:39 AM
The a.c. button turns on both fans. The new fan temp switch in the thermostat housing jumping it turns on both fans.. both thermostats opened fully when placed in hot water..
I have heard of drilling a bigger air hole in the top of thermostats .. I wonder if I just had an air pocket in there
  #80
Old 03-26-2019, 08:52 AM
Ok I thought the fans weren't turning on. It could very well have been an air pocket. Do you have everything back in as it should
Quick Reply: Cooling Fans Issue
