Cooling fans not working
Old 01-04-2008 | 05:51 PM
SteveZ's Avatar
Default Cooling fans not working
I have a 92 accord ex. Both coolings only come on when a/c button is pressed. With a/c off temp guage at normal fan never comes on. I did try jumping the sensor at the top hose thermostat housing. The fan still didn't come on. Also my lower radiator hose always seem cold. Car never over heats. HELP
Old 01-04-2008 | 06:02 PM
sir_nasty's Avatar
Default RE: Cooling fans not working
first things first, have you checked your coolant level? Does the upper radiator hose heat up?
Old 01-04-2008 | 06:09 PM
SteveZ's Avatar
Yes it does and coolant level is fine.
Old 01-04-2008 | 06:18 PM
sir_nasty's Avatar
if the car never overheats but lower hose is always cold then start the car, let it get up to temp, the upper hose should build pressure and become much harder, once the car reachs operating temp the upper hose should get a bit "soft" again since the thermostat opens up... If the thermostat is opening up normally then we'll move on to testing the sensors.... Since both fans come on with the A/C at lest you know the motors are fine
Old 01-04-2008 | 09:41 PM
HondatechAV6's Avatar
if the lower hose never gets hot the thermostat is stuck open. replace it. the fans will never come on if the lower radiator hose never heats up.
make sure you jump the connector, not the sensor.
Old 01-05-2008 | 10:21 AM
smaglik's Avatar
could be a fuse or a switch...i had a similar issue on my 94
Old 01-05-2008 | 10:29 AM
hondadude's Avatar
hope this help you.
[IMG]local://upfiles/5417/1163457F0EC64481BB26AE2A415935D5.jpg[/IMG]
Old 01-05-2008 | 11:15 AM
SteveZ's Avatar
I jumped the sensor where the top hose connect to the engine nothing happened. I have since read that the sensor is located at the lower hose connection at the engine. Looking with a flashlight I can't find it. HELP PLEASE!!
Old 01-05-2008 | 12:29 PM
SteveZ's Avatar
Ok just found the sensor at the lower radiator hose connection. Jumped the connection with ignition ON both fans came on. Also jumped the sensor connection at the upper radiator hose connection with ignition OFF one fan came on. The thermostat is original I ordered on today and will install when it arrives. I'll let you know if this solves the problem.
Old 01-05-2008 | 03:38 PM
nafango2's Avatar
im confused, the lower radiator shouldnt be getting hot, its coming from the rad...
