Cracked Cam Cap H22A HELP
Hi everyone, to make this story short, im from New Zealand and I own an Accord Euro R CL1. I was changing the distributor o ring as it was leaking. I just got this car and im not mechanically inclined at all so I am bound to **** up one way or another.
Upon changing the distributor o ring and tightening the distributor back on, I didn't realise that the distributor is meant to sit flush in the cam cap. So I just tightened the distributor nuts and the distributor holder cracked! this happened a few weeks ago and I used jb weld and clamped the piece together and let it sit for 24 hours. Lined up the distributor on correctly and the cars been running fine no issues.
But have I damaged something in the long run? im currently a student so changing the entire head would be far too costly for me. Any suggestions on my situation?
Thanks for all your help!
I hope this helps.
Those bearing caps are all bored together with the head itself, so they aren't available separately. Boneyards are probably a different story...
If you can find one, you'll probably have to go to a machine shop anyway to have it machined to fit.
As long as that bolt that is exposed is holding down the cam bearing and you don't have an oil leak, then you should be fine.
If that cap comes loose, then you'll have to find a replacement part. You might find a shop that can weld the part back together? Is that cap aluminum, steel, or cast iron?
Orz
04-20-2018 11:50 AM
John-Angela Hileman
01-13-2017 09:04 PM
strat
10-10-2008 11:51 AM
