Cracked Head Gasket
Cracked Head Gasket
Hello again,
My 2000 Honda Accord has a cracked head gasket. I have to put antifreeze in it at least twice a week. It is leaking into the oil so I have to keep an eye on how often to change it. Does anyone know what it may cost to get the head gasket changed? Also while the head is off I will have the timing belt, water pump and all other belts changed as well.
thanks again,
thanks again,
You don't say where you are, but in my neck of the woods (a small city, but well enough to do area)
a timing belt and pump at the dealer was quoted $720+pump cost+tax based on son's '93 accord.
I think total ballparked to $900. This, being dealer, would likely be highest cost shop.
Head gasket & external belts would be on top of that for you. I don't guess these.
Hmmm, are you completely sure you have a bad head gasket? What diagnostics did you employ to bring you to that conclusion?
ziggy!talon
04-15-2008 02:03 PM
thunder_x
07-09-2007 12:57 PM
