Curing a Cat Cover Rattle??
Old 01-03-2009 | 03:44 PM
JeffB's Avatar
Default Curing a Cat Cover Rattle??
My 04 V6 (90K miles) just developed a rattle that only occurs at EXACTLY 2000 RPM under load (never in neutral/park) and for a few seconds when cold. It doesnt matter what gear I'm in or car speed. The rattle is in the front of the engine. At first I thought the worst...tranny problem. But I was able to start it up one morning and run under the hood while rattling and foundit was the cover for the catalytic converterjust behind the radiator. I could touch the cover with my hand and stop the rattling. (For some reason,my Helm V6 supplement does not have a page showing the exhaust manifoldbutI assume this is a cat with the 2nd in the usual spot under the car.)
Anyway...all 4 bolts on this heat shield are tight and since it only occurs when the car is in motion, I can't figure out why it rattles or what to do to stop it.[sm=smiley29.gif]Its not hurting anything except my nerves...its pretty loud and annoying.
Has anyone had a similar problem and found out the miracle cure??
Thanks!!
Jeff
Old 01-03-2009 | 05:59 PM
BlkCurrantKord's Avatar
Default RE: Curing a Cat Cover Rattle??
Remove the shield...but seeing how your car is fairly new, could still be covered under your warranty.
Old 01-04-2009 | 12:35 PM
JeffB's Avatar
After inspecting further, I found that the cover screws were tight, but 2 of the L shaped holding brackets had rusted thru. Nothing to hold it in place and the cover was rattling against the exhaust pipe.
Thanks anyway!
Jeff
Old 01-05-2009 | 04:06 PM
swordfish7769's Avatar
Same thing happened with my '97. I took two large hose claps and put them together to fit around the converter to hold the shield tight.
swordfish7769
grim_reaper
02-22-2012 09:59 AM
pyaarawala
06-01-2007 02:19 PM
MAxElement
03-16-2007 05:52 AM
00calicoupemd
05-07-2006 02:01 PM
sir_nasty
03-10-2006 05:25 PM
