CV Joint Problem
Old 06-09-2012 | 08:00 PM
tmounib's Avatar
Default CV Joint Problem
Is it possible that my drive shaft has extended in length? I am unable to re-install my knuckle because the upper and lower ball joints won’t align, as if the outer CV joint has been displaced outwardly. The inner boot looks like it is over stretched / somehow flattened. I don’t remember pulling on the axle shaft while removing the knuckle. Yes, I can feel a play in the axle, may be half an inch. How bad is this?
I am in the middle of a job of replacing my front wheel bearing 2-door 95 Honda Accord. I watched tens of videos and read DIY manuals. It is turning terribly wrong. Both right and left shafts are recent from 9 months ago
Old 06-09-2012 | 08:35 PM
crispin's Avatar
1) you should start your own thread instead of adding to one that is years old.
2) the axles can be compressed or expanded, I do not think it is possible to easily pull the ***** from the cup. What that means is that if the CV axle is extended further than you need it to reconnect everything you should be able to push on it and compress it shorter.
Also make sure it has not pulled out of the transmission.
Old 06-09-2012 | 10:44 PM
Remove the clamp for the inboard boot & look around. I bet the tripod bearing has pulled all the way out from the inner-driver.
Shocker
08-15-2007 01:39 PM
hooey
02-20-2007 12:27 PM
skareb
09-21-2006 01:24 PM
di2iftwood
01-03-2006 06:00 PM
77911S
04-27-2005 10:51 PM
