CV Joint Replacement on 1999 Honda Accord?
I've been doing some research on replacing the CV Joint Axles on both sides. RockAuto has both sides for $45-$50 per side (R&L).
When you go to tighten down the suspension (tie rod and spindle portions) as you are putting it all back together, do you need to tighten them down under load (weight on the tire)?
Do I need anything special, outside of tools and the actual CV joint axles when doing this repair? Gaskets or c-clips?
I found out that my spindle nut is 36mm by the way.
the axles should come with new nuts. snug everything and then do final torque with car on the ground. no gaskets, but if you rip a seal you'll have to replace it. liberally coat splines that go into the trans with trans fluid, that will help the seal live through the trauma.
Awesome, thanks for the info!
Part # check:
I have a 3.0L AUTO (1999 Honda Accord).
The part number I get off rockauto is APWI Part # HO8237A (for left) and APWI Part # HO8238A (for right).
It does not ask if it is for a manual or not or did all 3.0L's come in AUTO form? I also have ABS, will it be compatible?
Part # check:
barbers
08-14-2013 02:13 PM
stonie1
08-18-2010 07:48 PM
