Dealer says Honda changed oil recommendations
My son's 2010 Accord EX was brought in to the dealer for an oil change. The oil fill cap has imprinted on it 5W-20 but the service writer said Honda changed their recommendations to 0W-20 synthetic (full or blend). I went ahead with this; they charged $58 for the oil change.
Is this accurate--Honda recommends 0W-20 and for an older model, the 2010? Up until today, the car has had 5W-20 conventional/organic oil at every change.
Insist on 5W-20 if that is what you prefer and also to save some money for the 2010 Accord.
Honda usually publishes engine oil applications guides annually. The service writer may have been mistaken.
I don't recall them all at this moment; but, there were a few powertrain changes to the 2011 Accord vs. 2010 Accord.
I don't have a preference and while the synthetic blend is expensive, I'm okay if it benefits the car.
Shipo--what do you see as superior about using 0W-20 over 5W-20?
BTW: I live in northern Alabama where it's hot in the summer but in the winter, once in awhile overnight temps. fall to low teens. Not sure if that makes a difference.
Oil in the 0W-20 grade is a full synthetic (at least I've yet to see a lesser oil in that grade), which by definition means it will exceed the performance of a 5W-20 semi-synthetic due to the superior quality of the base stocks for the oil and the need for significanly fewer additives (which in turn means the oil has a greater capacity to safely carry contaminates).
Base stocks aside, 0W-20 will pump up to the top end of your engine quicker following a cold start, even if said "cold start" is in the middle of an Alabama summer.
Okay, well, I appreciate the answers and I now know more about the differences in oil. Just one more question: if you use full or partial synthetic ("blend" as my dealer calls it), do you do any harm if you get an oil change with conventional / organic oil on occasion? I ask because I had a blend in a 1999 Accord and then forgot about it when I went to a quickie oil change place. Thanks again!
