Deleting ABS
Deleting ABS
Hello to all and thank you for reading my post. My 95 EX was in a accident and the ABS UNIT was destroyed. I fixed everything but the unit. I can't find a NEW or USED unit at this point. So, I went to a salvage yard and removed a proportion valve from a non ABS car to install in mine so I can delete my unit. The problem is, nothing will line up of course, and if this can be done, where do the lines go?? If I must, I will go back to the salvage yard for the lines and or direction of the lines. Thank you
Is your 95 EX a 4-cylinder or 6-cylinder?
It looks like the 94-97 accords used the same abs module along with the acura integra.
You can check out a site like car-part.com that searches junkyards for parts, where you can sort by price or distance. You may be able to find a replacement on that site where you can reconnect your original brake lines.
My thought was installing a non-functional ABS would be easier than swapping over all of the non-abs accord lines as long as the abs unit was not leaking. You wouldn't have a functioning abs, but the install would be simpler.
You best bet is to look up the OEM part numbers for the lines on a non-abs accord vs an abs accord on a site like hondapartsnow.com. Then you can see what items you need to pull from the non-abs accord at the junkyard. Hopefully, you won't have to pull the lines that run under the plastic shield going to the rear wheels for the lines.
pturnbul
05-03-2007 02:30 PM
