dented door
dented door
I got sideswiped this weekend and dented the back drivers side door almost from front to back. Is there access to the outside metal if I remove the inner liner so I could try to push it out? I am not sure I will even be able to lower the window as the dent is so deep. I thought about using a dent puller but would rather not put holes in the outside if not necessary.
Larry
Larry
cyberdork
09-25-2008 06:24 PM
