Differential Growl?
Differential Growl?
New to the forums!
02 Accord EX 4dr AT
260K on transmission, 135K on engine (swapped myself 17 months ago) which was done 15K miles ago.
I am hearing a low growl at 30 mph. Does not matter if in drive or neutral. No growl at standstill, in neutral, regardless of what revs. Growl does diminish with deceleration.
Under vehicle on jackstands, rotating the fronts in the same direction produces what I think is the noise (faintly at hand speeds) and in opposite direction produces the noise too. Sound seems to be coming from the differential area. Holding one wheel still at a time, trying both wheels, does not eliminate noise either way (thus not CV joints I think).
The fluid level is OK, have not had to top off once since the swap, thus I think no AT fluid leaks (no obvious AT fluid on tranny or floor).
Any thoughts other than looking for a "new" used tranny?
Thanks, Tom.
04 Odyssey EX
02 Accord EX AT
99 Accord EX MT
02 Accord EX 4dr AT
Thanks, Tom.
04 Odyssey EX
02 Accord EX AT
99 Accord EX MT
Welcome to HAF.
A noise over the internet is always fun to figure out.
So with that said - I would also think about/check for a wheel bearing going bad? Not a true test but...find a nice big, empty parking lot. At the speed the noise is happening - try turning the car left and right. Does the nosie seem to change in anyway?
Also, with the car on stands grab the inner CV joint and push it up and down and check for excessive play. Do that for both sides and see if one side is different from the other. Although not common to fail on Honda's it could be the a carrier bearing is failing. Also check to see that each of the inner CV's are completely in as that will make a noise as you described.
Gotta crack the case to replace carrier bearings.
joede
12-28-2011 05:12 PM
