Difficulty starting after New Battery Installation
I have a 2008 Honda Accord with 58,000 miles, I recently had a new battery installed, and since then I have had trouble starting it.
The problem is that when I turn on the ignition, nothing happens.... I turn it off and wait 15 seconds and try again. I have to repeat this 3 or 4 times before the car will start.
They tell me at the garage that after I partially turn on the ignition, wait until the lights come on the dashboard, and then turn the ignition all the way for 7-8 seconds and then turn off and then repeat as necessary until it starts.
I never encountered this problem since I have had the car.
What ever happened to just turn the key to start and be on my merry way?
Any suggestions?
Thanks,
Jim
Any suggestions?
Thanks,
Jim
Is this a V6 or 4 cylinder? Do you know what battery size was installed and the CCA (cold cranking amps) of the new battery?
Try this, disconnect the battery cables (negative cable first for safety). Touch the two battery cables together for about 5 minutes to discharge any residual power remaining in electrical components (e.g, capacitors, etc.). Make sure not to touch the battery terminals (posts) while doing this. This will act as a reset.
Reconnect the battery terminals, positive side first, then negative last.
Enter your radio security code to enable the radio again.
Edit: For additional clarification, disconnect both battery cables while doing this and don't have them touch the battery posts.
FWIW, amazing that an OEM battery should need replacement after only 3 yrs., I'd a figured 5 yrs minimum, minimum life.
Even money bet someone sold you a new battery and screwed up your car in the installation. Bet wasn't the dealer, Sears or any reputable place...
luck
d*mn, I'd take it back to the garage pronto and have them demonstrate to me how to start it from putting the key in ... step #1.
luck
luck
Also, I had a typo in my original post.... the car is 5 years old and not 3. I had put the year of purchase of our 2nd car by mistake.
Since my post, I have an appointment at the Honda Dealer on Monday morning.
If there are any additional ideas, I would like to hear them, so that I could probably ask the Service manager to check...
Thanks,
Jim
Hello there,
Birchwood Honda told me that if I don't drive my car at least every 3 days then the battery will die. The Battery CCA is what everyone is talking about and is how many amps a battery is able to deliver for 30 seconds at minus 17.7 degrees Celsius. @ that temp a 12 volt battery will hold a 7.2 volts. With out testing of the battery we wouldn't know the condition of the battery. It just might be to cold outside for that battery to work and I recommend at this point and with the info given to try a heater to keep the battery from freezing.
Regards,
Anthony
_______________
XkGlow
Regards,
Anthony
_______________
XkGlow
Steve Remich
07-15-2013 12:54 PM
maichou87
12-04-2011 09:14 AM
