Distributor o-ring - where does it go exactly?
Help! Read a lot of threads on replacing the distributor o-ring but it is very unclear about exactly where it goes. Got an 97 Accord (4 cyl) with a bad leak where the distributor connects to the engine. Pulled it off and could not see an old o-ring anywhere. Now I don't know where to put the new one. I can slide it over the protruding part of the distributor that goes into the engine, but it's somewhat loose there. Or I can slide it over that protrusion until it is flush with the flat face of the distributor that connects flush with the engine.
Don't know if that makes any sense as all of this is so hard to describe. Bottom line is, when I put the distributor back on, just before I bolt it in, should I be able to see the o-ring as it makes contact between the distributor and engine or should I not see it, as it's been inserted into the engine?
Thanks in advance for any help you can provide!
~Paul
~Paul
The distributor has a slot cut around the shaft and takes and the O ring. There is a seal for the inside of the distributor but that only needs to be replaced if there is oil leak under the cap.
Greatly appreciate the quick response!
Success!
Success! Just thought I'd follow up and let ya know; the reason I couldn't get the new o-ring on was because the old one was there all along! A mechanic buddy of mind came over and instantly recognized it. I had thought it was part of the distributor shaft because the thing was flat and hard; but a quick cut with a knife set it free, making room for the new one. Wow. Lesson learned.
Thanks again for your help guys.
