does 6cyl 2.7 have balance belt or shaft?
Old 10-23-2012 | 11:52 PM
snicrep's Avatar
Default does 6cyl 2.7 have balance belt or shaft?
i wondering if my 96 2.7 has a balance proceedure like ive been reading on the 4 cyl. the reason i ask is my engine has a little vibration when revved. not at idle and not enough to be a major nuisance, but noticible. my next choice would b an engine mount but i dont see alot of play.
Old 10-24-2012 | 12:08 AM
I am not familiar with how the V6 accord is set up for the timing belt and balance belt.
I would suggest cleaning the EGR ports on top of the intake. There is a plate (#5) that you have to remove and there are ports on top that you might want to clean out. There may be channels in the plate that can get clogged too.
Old 10-24-2012 | 12:26 AM
There is no balancer shaft or belt for the V6.
Accord V6 timing belt
To add to PAHonda's post regarding the EGR ports, see attached pics.
Attached Thumbnails does 6cyl 2.7 have balance belt or shaft?-95-97-accord-v6-egr-port-service-plate-page-1.jpg   does 6cyl 2.7 have balance belt or shaft?-95-97-accord-v6-egr-port-service-plate-page-2.jpg
Old 10-24-2012 | 12:45 AM
snicrep's Avatar
thanks for the fast reply. thats one less thing to mess with. Ill ck the carbon. but in the end itll prob be motor mts
Old 10-24-2012 | 10:53 AM
How are the maintenance items? IF you're pushing the age of the sparkplugs (just for example), maybe they're leading to uneven power from cylinder to cylinder.
nrmskate
05-16-2012 05:27 PM
kris_loehr
11-26-2008 06:52 PM
Vcong
09-09-2008 12:15 PM
mrwigglezdj
12-23-2007 11:33 PM
accord4sroy
04-22-2006 03:40 PM
