Dome Lights 2003-2007 Accord EX
Hello,
I've read a few posts about the dome lights not working and people mention to check fuses under the hood and kick panel. I don't think I have that problem in my car! I have checked fuses and replaced light bulbs and still have no juice going to the dome lights in the overhead! The lights on the doors turn on when I open the door! What else should I check for?
Pull the dome light assembly down chk to see if you have power and ground on the wires going to it
by the way you should never replace parts till issue is properly diagnosed , I know that bulbs are cheap, still,
diagnose is the key to a proper fix
