Door panel, front bumper
I have two questions. How do I get the bezel around the inside door handle off. The one by the power lock switch. I have removed the screw, but it still feels like it's being held on by something.
Also, how do I remove the front bumper from this car. It looks like it is held on by clips along the top. Some are under the headlights but it's not obvious to me how to remove the headlights. I took out the bolts on the top, but the light assemblies are still in there tight.
The car is a 1990 Accord EX sedan.
Thanks,
Dale
Thanks,
Dale
RE: Door panel, front bumper
You should download a shop manual from hondahookup.com/manuals for the 91 accord. It will be pretty much the same as you 90 accord.
Door info is on page 14-5
The door handle needs to be pushed towards the front of the car, then you can pull it out.
14-53 talks about front bumper removal.
There is also a link in the DIY section poster by deserthonda (4th post from the top) that goes to a site with a complete Chilton manual for almost any car. Chilton sucks in some areas, but is decent in others. I think your answer is there.
jza240sx
04-30-2013 04:14 PM
connam06
03-27-2013 07:47 AM
