Door rattle
Old 12-10-2008 | 02:13 AM
sihawker
Default Door rattle
2006 exl-nav
The passenger door rattles very annoying. I partially removed the door pannel. I can't remove the whole thing though. It seems to be coming from the metal inside the door. Any thoughts?
Thanks
Old 12-10-2008 | 07:27 PM
Default RE: Door rattle
Is the car still under warranty?
Old 02-19-2009 | 09:55 AM
tobybul's Avatar
Default rattle
just got a 2007 Accord EX 30k miles and noticed rattle/crinkle sound on drivers door whenever I go over bumps or dips. Brought it to dealer and they fixed it under wty. I watched the tech open the door panel. Honda uses a fairly thick plastic sheet thats somewhat molded so it goes in and out of the door access openings as a moisture barrier between the door and the panel. It appears this maybe the culprit. The tech put "window" tape (looks like black masking tape) in strategic spots. He also put dbl sided foam tape along the points where the edge or the door panel meets the door.
I'm going back today to have them do it on the passenger side door as now I'm noticing it on that too.
Although they did not say, but this may be a common issue. the tech looked liked he had done this a few times before.
rkm152
09-28-2008 03:25 AM
rkm152
09-28-2008 03:19 AM
mahones
01-10-2008 08:08 PM
HondaAccordFan
10-02-2007 11:14 AM
billeethakid
06-12-2007 04:36 PM
