Drive belt maintenance?
Old 04-22-2009 | 07:44 PM
Jeff247's Avatar
Default Drive belt maintenance?
Looks like I am out of the range on the auto belt tension (see pic). Does the belt need changing (see pic)? It's a 2003 Accord 4 cyl with 212K miles. Thanks
Attached Thumbnails Drive belt maintenance?-dsc02733.jpg   Drive belt maintenance?-dsc02741.jpg
Old 04-22-2009 | 07:51 PM
hondadude's Avatar
Is the belt squealing on start up?
If it is the original belt it should probably be replaced.
Old 04-22-2009 | 08:00 PM
Jeff247's Avatar
Default It's original
It is the original belt. No squealing. Just looking at maintenance records and checking on things that could be overdue. Things seem to last longer for me. Most miles are on the NYS Thruway. Brakes went way over expected life because I drive 125 at a clip with no stopping. I don't think I put my first set of brake pad on til 100K miles!!
Old 04-23-2009 | 07:35 AM
The visual condition of the belt looks OK, but the tensioner position says the belt has stretched beyond spec. I'd replace it - at 212k miles, I think you got your money's worth out of that belt.
ps... Take a real good look at the tensioner pulley bearing, and any other stuff up there.
Old 04-23-2009 | 08:21 AM
Smile
Also look at the underside of that belt to see if it has cracks across it..if so , it's past due..
Old 04-24-2009 | 08:43 AM
Jeff247's Avatar
Default Having it replaced
Just got quotes back from two Honda dealers. It's going to be $125 for part, labor and tax. Looks like I got my moneys worth!! Thanks.
Old 04-24-2009 | 10:26 AM
drummer1279's Avatar
how do you get rid of a squealing belt on startup?
Old 04-27-2009 | 08:21 AM
Jeff, you can probably save half of that if you change the belt yourself. After studying the path of the belt going around each pulley (so you can remember), release the spring-loaded tensioner, & remove the belt.
Drummer, that depends on the cause of the noise. Loose belt? Old belt (hardened & slippery with age)? Squeaking A/C compressor clutch?
Reboticon
08-24-2010 07:50 AM
pmatos
04-12-2009 02:04 AM
ksar
10-17-2008 10:27 AM
siciliangrl
01-05-2007 10:51 PM
Jeff247
12-29-2006 08:15 PM
