ecm code
ecm code
Just picked up an 87 Accord, 97000 miles, the PCM flashes on just after you start to drive. I checked the code. It flashed 12 times consecutive, no long flash then short flashed, just 12 flashes.
I pulled the fuse to ecu and cleared the code
thanks
willie
87 Accord LXi, auto
91 Previa LE
96 Impala SS
thanks
willie
87 Accord LXi, auto
91 Previa LE
96 Impala SS
If you don't have a manual download the "86-89 Accord Secan" manual from Online Manuals link in DIY forum. Secan is misspelled sedan.
Review how to read codes and read your codes again when/if codes reappear. You may have two codes adding up to 12 (5+7), if you missed a long pause. Manual shows no code 12 as pointed out.
Parkavenue
09-18-2006 07:59 PM
