ECT2 on 2007 accord with 03-05 rad
I have a friend who got a radiator for his 2007 Accord and the ECT2 sensor location is clearly the big size hole for the thermal switch. (I assume he was sold a radiator for a 2003-05)
I need a thread adapter or a thermal sensor that fits the larger size hole. (I'll double check, but I think it was M12 1.5 to M18 1.5 or something similar).
Due to it being winter he is not overheating at the moment, and his commute is highway.
Any parts swap geniuses out there know of an easy fix for this that costs less than $20?
Thanks in advance.
Edit: My current best bet is either EQUUS 6862 / 9862 Gauge sender adapter or "GlowShift 1/8-27 NPT Female to M18 P-1.5 Male Thread Adapter" and a M12 1.50mm tap: https://www.acehardware.com/departme...and-dies/23773
Not plug and play because I need to tap it, but might be available locally for around $20
Thanks in advance.
I ran across a thread while googling which mentions the radiator may come with the adapter, mine did not as far as I could see.
