EGR Valve disconnect
Old 07-09-2007 | 09:35 PM
dboy's Avatar
Default EGR Valve disconnect
I have a 98 honda accord 4 cylinder.. the Check engine light reads an egr valve problem . Anyways..i replaced the valve with one from another honda engine..but the engine light still comes on.. Question If i disconnect the electrical plug from the valve will it damage my engine ? And if i did unplug the the cable will my check engine light come on after i reset the check engine light...
Old 07-09-2007 | 11:37 PM
Default RE: EGR Valve disconnect
The CEL will come on if you unplug the EGR valve.
Search for cleaning the EGR ports, because they are most likely clogged.
Old 07-10-2007 | 06:34 AM
Chiovnidca's Avatar
ORIGINAL: dboy
What's the code?
Old 07-10-2007 | 07:37 AM
dboy's Avatar
I forgot the code.but it has something to do with the egr not flowing or something....Anyone know how much it cost to clean ports?
Old 07-10-2007 | 11:04 AM
Chiovnidca's Avatar
ORIGINAL: dboy
The no flow codes rarely caused by the valve. Clean out that port.
NZXTInerTia
07-20-2012 03:06 AM
archangel_1988
12-13-2011 11:43 PM
uraceulose
10-06-2009 08:19 PM
RJLhonda
09-09-2008 01:05 AM
ducatiff
07-07-2007 12:22 AM
Quick Reply: EGR Valve disconnect
