Electrical Connector - Where does this go?
'97 Accord EX
Came across this electrical connector that was unplugged while working under the dash. I tried to find the plug where it should go, but can't. What is it? I had a shop replace my clutch master cylinder 4-5 months ago and suspect they might have un-clipped it during the installation.
See pics. Connector isdriver's side, as part of a wire harness above the interior fuse box.
Wirecolors are: Orange, Black/white, Yellow/Red
Thanks!
http://www.nigelspearlnecklace.com/accord/1.html
http://www.nigelspearlnecklace.com/accord/2.html
RE: Electrical Connector - Where does this go?
I suspect it is simply an unused connector. If you have a Honda Shop Manual, check the "Connector Identification and Wire Harness Routing" charts for 3-wire connectors. I saw two possibilities; C419 -security system (optional) andC427-Clutch Switch. Then go to wiring diagrams for these systems, find the three wire colors you have,and identify the connector.
redbull-1
02-24-2014 12:30 AM
accord, box, chart, connection, connector, connectors, cylinder, electrical, harness, honda, interior, master, orange, pics, wire
