electrical problem
Old 01-16-2006 | 08:49 PM
Mydnght2u
Default electrical problem
I have a 1999 Accord EX. The lights on the clock and auto shift column on the floor do not illuminate at night. I am able to see what gear I am in by using the dash display only. I have already checked the fuses and they all tested fine. Does someone have any idea what the problem might be?
Old 01-16-2006 | 11:55 PM
TYTALEX's Avatar
Default RE: electrical problem
Light bulbs? Possible harness damage. I would start right at the bulb and see if you have voltage.
Old 01-17-2006 | 07:10 AM
lightshow's Avatar
yup whip out your trusty old multimeter, you ve got one right? also......you have a set of fuses that are under the hood on the passenger side. did you check those? there is a fuse under there that controls the clock. i just burned mine out the other day with my big *** stereo.
lightshow
Old 01-17-2006 | 07:18 PM
deserthonda's Avatar
you checked both fuses correct??
driver's under dash fuse box fuse # 9 .. 7.5 amps
passenger under dash fuse box fuse # 13 ..7.5 amps
94exsedan35094
02-05-2008 08:44 AM
calenatar
03-10-2006 03:23 PM
eddyfurukawa
02-13-2006 03:15 PM
qbtarget
02-13-2006 01:56 PM
dude9571
02-11-2006 12:17 AM
Quick Reply: electrical problem
