engine damper kits
Old 06-14-2008 | 09:46 PM
honda97acc's Avatar
Default engine damper kits
Just wanted to know if engine damper kits are worth it. Do they realy help reduce the wear on the engine mounts. would they be worth it for a 97 accoed that has over 230,000 miles on it. thanks.
Old 06-15-2008 | 09:09 AM
Default RE: engine damper kits
Do you mean the rear hydraulic motor mount which has a built in dampener?
Never heard of anything else, but tell us more.
My 94EX w/ 220K miles runs smooth w/ no modifications.
Old 06-15-2008 | 11:16 AM
honda97acc's Avatar
Enlarge Image
[/align] ENGINE DAMPER KIT [/align] This add-on engine damper mounts from any place on the engine to the chassis. Includes universal brackets for attachment.
Features:
-Increase engine stability
-Reduces wear on factory mounts
-Reduce torque loss from excesive engine movement
-Includes rubber isolators and polyurethane isolators
this is what i was looking at. didnt know very much about it. but it seems that if it stops the engine from rocking that it might help some i guess.
Old 06-15-2008 | 12:04 PM
The 94-97 Accord will run smoothly w/ good motor mounts and correctly functioning idle air control valve (IACV). Seesticky on rough idle to learn how to fix IACV.
Unlessdampeneroutfithave a very good installation manual w/ specific instructions for your model Accord, you may have significant difficulties w/ installation. Much easier to replace existing motor mounts and correct IACV than mount this device.
Device will have no affect on engine torque delivery IMO.
good lukc
Old 06-15-2008 | 04:29 PM
honda97acc's Avatar
thanks for the help texashonda
baconsum1
12-12-2008 03:22 PM
ziwang55
06-04-2008 01:22 PM
falkore24
10-23-2007 12:28 PM
stefanb21487
07-21-2007 06:03 PM
sleep depervation
03-13-2006 07:06 PM
