Engine Died While Driving, Won't Start
#22
I believe its your timing belt? when you crank it over does the engine sound abnormal to you?
If its the timing belt you will get no spark no fire power,the engine will crank slower than usual and sound more like a winding than a crank
#23
It's an interference engine so you need to be careful about camshaft position.
You've already been cranking the engine without the cam spinning. So if you're gonna bend the valves then they're already bent.
Turn the crankshaft until the TDC timing mark is 90-degrees away from the pointer. That will position all 4 pistons at mid-stroke, and now you can turn the camshaft any which way you want.
By turning the camshaft, you should go through the motions of checking your valve clearances. Any that are way too large are bent valves. If you see that, you can decide whether to have the head rebuild or look for a used engine.
#24
I already know it's not getting spark. I've tested it several times. Plus with the camshaft not spinning while cranking that's pretty much a dead giveaway that there's something wrong with the timing belt.
When I crank the motor, it does sound very abnormal. But it doesn't crank slow, it cranks fast. Sounds like there's no compression and it's a whirring sound. It's not too much of a whirring sound, you can tell there's compression from what I think I can hear. I'm wondering if the valves are stuck halfway open.
I really hope I didn't bend a valve. The car would not be getting a new motor and would probably be scrap. This would just mean I now have three cars sitting in front of my house that don't run. Worst of all, I don't have a driveway, so it's my three dead cars sitting on the side of the road, plus the three other cars that we have that do run (Ma's car, Dad's car, and bro's car)
#27
That bit about all 4 pistons being at mid-stroke is for in-line 4-cyl engines. I had to look up whether the '95 LX coupe was offerred in V-6, and it wasn't. Otherwise, it's very important to say whether you have 4-cyl or V-6 because they may as well have been completely different cars.
#28
Well it was the timing belt and no valves appear to have struck... all that aside I took the ignitor out (ignition control module) and completely forgot the order of wires that it went in. Anyone know this off hand or could tell me where I can find out?
Kristen Kallos Sager
06-22-2013 11:04 PM
HondaAccord93
03-18-2009 08:40 PM
