Engine dies with AC on - Compressor turned off
My girlfriend just bought a 1990 accord and the only real problem we are noticing is that if we turn the ac on past two clicks it bogs down and eventually dies after maybe 5 seconds, It seems like a vacuum leak of some sort but i cannot find a vacuum line that could be causing this to happen. Also we have the compressor unplugged so that isnt the issue and the ac blows ice cold on two clicks.
1990 honda accord lx f22a1 sedan auto
Can you re-explain what you are describing?
There is a device that raises the idle speed when the compressor comes on.
Another member with better experience will need to give a more detailed answer to help you.
I will PM someone who I think knows more about this issue for you and ask them to reply here.
Engine idle air control valve opens more rapidly (ECU commands open/clos time) to absorb compressor AC load w/o excessive idle rpm loss. It is likely the iacv is blocked w/ grime or less likely, electrically faulty.
IACV can be removed and cleaned. Clean throttle plate and throttle bore around throttle plate. Clean inlet/outlet ports to IACV. Throttle body cleaner should be used. See DIY procedures for help on this job.
Is the Check Engine Light (CEL) on? If yes, then see DIY procedure to extract codes and post the codes.
I would take the belt off the compressor and see what happens when you turn it on.
If the car has the same problems then you have a IACV problem
If it does not have the same problem then you have a problem with the compressor, likely bad bearings in the compressor.
