engine light on for code p1457
Old 10-22-2013 | 08:35 PM
Yessy Consuegra's Avatar
Default engine light on for code p1457
Hi, hf. I have a honda accord 1998 v6. The engine light cmturned on. The code it given is p1457. Does anyone have a similar situation? Any help on which piece should I change?
Old 10-23-2013 | 02:39 AM
Moved to the correct forum thread..Right Here.
Old 10-23-2013 | 07:29 PM
This will take some testing.....gas cap, shut or two way valve are all in play.
Have some time and the tools to test?
Old 10-23-2013 | 08:16 PM
P1457 is leak detected in EVAP control system (EVAP control canister system). Although it may be something else on the canister side of the EVAP system, some of the usual culprits are the EVAP bypass solenoid valve or the EVAP vent shut valve.
If it was the gas cap, that would be P1456, leaked detected in EVAP Control System (Fuel Tank System).
See this links and thread:
Honda TSB 03-001
https://www.hondaaccordforum.com/for...57-code-41800/
https://www.hondaaccordforum.com/for...-1999-a-27179/
Old 10-24-2013 | 04:01 AM
Thankz guy. Poorman212 I do have the tools and time to test. I found a full canister set for about $50. Should I buy and replace mine or test?
Old 10-26-2013 | 08:46 AM
Well I'm a fan of testing things before replacing.
One thing you might want to do is get a shop manual for this car. I'm not putting them down but I am NOT talking about a haynes or chilton book.......go someplace like automanualsource dot com and get one.
If you live in a place where rust is an issue, the two screws/bolts that hold the shut valve to the canister get rusted and become a real pain to remove.
Old 11-19-2013 | 08:06 AM
nnvsabari's Avatar
Did you figure out where the leak was?
Old 12-30-2013 | 07:34 PM
Not yet. I have been really busy. But I am looking to replace the whole canister piece.
Old 12-30-2013 | 07:50 PM
bpp's Avatar
bpp
Isnt it almost always the Vent Shut Valve(17310-S0X-A0) that needs to be replaced? I agree that its almost always worth testing but in this case, it usually is a safe bet. Its cheap, not hard to do, and will most likely go bad at some point.
Old 12-30-2013 | 07:55 PM
No, it is not almost always the vent shut valve. See post #4 above and the links.
Yessy Consuegra
01-18-2014 09:21 PM
executiveg
12-29-2012 12:38 PM
bigant
12-02-2008 05:10 AM
ajluu
01-03-2008 01:51 PM
zoominhuman
03-30-2007 07:55 PM
