Erratic Idle due to TPS?
Old 03-28-2008 | 05:38 PM
Tai_Boi
Default Erratic Idle due to TPS?
Is it logical? when i gas it, the car jerks only in the 1k-1.5k rpm range. I've checked with a local mechanic and he said its the TPS. Unforunatly, new ones go around 500+ since they dont sell the TPS by itself, but only with the whole damn throttle body. I just want to make sure this could be a problem b4 i empty out my wallet.
PS. I've already tried replacing IAC valve, and cleaned the intake manifold. no dice.
Opinions will be greatly appreciated, thanks guys.
94 Accord EX F22B1
Old 03-28-2008 | 06:36 PM
Chiovnidca's Avatar
Default RE: Erratic Idle due to TPS?
Try disconnecting the vacuum line to the egr valve and go for a drive. Does that change it?
Old 03-28-2008 | 07:10 PM
Tai_Boi
i'll have to do it tonight after work, i'll also have to find where it is...
Old 03-29-2008 | 02:08 AM
Tai_Boi maybe used to be chubug? from Hoston Texas.?
Welcome to the forums
falkore24
08-30-2011 02:23 PM
Raz93
07-08-2009 08:13 AM
delgadoe
02-03-2009 05:58 PM
Planefreak
10-29-2007 12:09 AM
mastar91169
05-11-2007 11:36 AM
