f22b2 or h22a
Old 05-26-2008, 07:05 AM
BlkCurrantKord's Avatar
Default RE: f22b2 or h22a
Trying to get 250+ whp out ofa naturally aspirated honda 4cyl is pretty hard to do and by the time you got there, it'd be a race only motor.
BTW - you dont need 110 octane to run 15psi. You can do it just fine on pump gas.
  #32
Old 05-26-2008, 12:43 PM
legal's Avatar
how much hp could i get by just turboing my f22? say at 10 or 15 psi?
saw f22b2 with 10 psi keep up with a evo with 24 psi.
im just really confused on what to do.
i just want a quick car.
  #33
Old 05-26-2008, 05:23 PM
10-15psi Depends on what turbo you want to use. Aim for a specific HP goal, then find out what you can afford to get you there.
  #34
Old 05-26-2008, 08:04 PM
legal's Avatar
hp goal would be 300.
price doesnt matter.
whats a good turbo to use?
and how come you see more vtecs turbod then you do non
  #35
Old 05-26-2008, 09:59 PM
B/C Vtec is "popular"
  #36
Old 05-26-2008, 11:34 PM
legal's Avatar
thats cheesy.
let me ask this then.
what would you suggest a good hp goal is?
daily driver. and how would i get it?
  #37
Old 05-27-2008, 10:00 AM
falkore24's Avatar
For a DD with FWD, anything over 350HP isn't going to be usable ..... unless you just want to smoke tires until they explode.
I'd recommend a turbo F22 with a micro-polished OEM crank, performance bushings, rods, pistons, rings, wrist pins and a turbo pushing 9 psi. I'd also get a 2 stage boost controller so you can switch to race mode and pump up the turbo to about 12.5 psi, but I'd keep it on the lower setting mostly.
  #38
Old 05-27-2008, 11:02 AM
legal's Avatar
ORIGINAL: falkore24
i like how that sounds
any specific turbo? and where can i get all of this?
websites?
thanks for all your info dood
  #39
Old 05-27-2008, 12:23 PM
falkore24's Avatar
You're going to have to research and run some calculations to figure out the turbo that is best for your car and driving style. Start with researching trim and AR. I've done research for my tC and the one that I am most interested in is the Garrett GT3076R .... still undecided on the trim. I'd expect that the right one for yours would be similar, but might not be the same one. I have a slightly larger engine that doesn't rev as high.
  #40
Old 05-27-2008, 01:00 PM
legal's Avatar
Quick Reply: f22b2 or h22a
