Fail Code PO848
P0848 is for a problem in the transmission oil pressure switch circuit. The problem could be the switch, damaged wiring/connector, or the PCM.
You are not in the US, so you will need to find a honda parts site for your car. In the US, the part number 28600-R94-004 and the parts diagram should help you locate the switch. Before replacing any parts, you may want to unplug that switch, and check the connector for any corrosion that could cause a poor connection.
