Failed MFR versus ECU versus Fuel Pump?
Old 08-23-2012 | 08:09 PM
Go to the common diy thread on top of the gen tech help forum. Open the online manuals thread. The honda-tech site has a 94 accord shop manual you can download.
Under the automatic transmission, there will be tests for those codes. Try doing some of the tests for each code.
This thread is getting long (thats ok), but am going to give some suggestions that may be repeats of before. Disconnect the battery. Clean all ends of both battery cables using a wire brush. The ground goes to to three places (fuse box, radiator support, and the engine block). The + goes to the fuse box and the starter.
See if this fixes the CEL problem.
The next thing I would do, use jumper cables and try jump starting the car. Low voltage/charge can cause strange things to happen.
  #72
Old 08-25-2012 | 01:06 PM
Dave Clark's Avatar
Anyone got a quick and dirty diagram on the sequence of the wires from the distributor to the engine block?
  #73
Old 08-25-2012 | 01:18 PM
Not sure what you mean. What are you trying to do?
  #74
Old 08-25-2012 | 07:31 PM
Dave Clark's Avatar
I took the wires off the distributor when I uncapped it/removed it; at any rate, I found the diagram/wiring sequence, so I'm good at this point.
HJCartman
08-17-2011 05:44 PM
kissbally78
01-18-2009 08:14 PM
marrymemercedes
07-03-2008 12:54 AM
SusanA
06-03-2008 12:56 PM
ouchevelles
05-07-2007 04:42 AM
